- Jun 6, 2009
That doesn't sound right. They should just pop right out with a little prying. Double check everything.
yes it does. ever hear of carrier bearing preload? When I install a carrier after rebuilding a diff, usually have to pound it in with a rubber malletS. IF you can just pull out a carrier simply, the bearings were pooched. I usually get someone to hold onto the pinion flange, and put a big ass wrench on one of the ring ear bolts, and as you pull down on wrench, it will turn the carrier out. That or MAKE a case spreader....bolt some angle iron (2 pcs parallel) to the case (diff cover holes) and put some threaded rod through them (top and bottom) and spin the nuts to spread the case....it doesnt take much, even a thousandth or two is enough often to allow the case to come out.
