- Aug 30, 2007
- Age
- 37
- Cass Co, Missouri
K, just lookin for somebody to confirm what I'm thinking will work.
What I got,
*94 Ranger w/ LED turn signals and running lights already installed.
*an Able2 Sho-Me 11.1005SF flasher
What I wanna do,
Wire flasher to control turn signal side of lights, both left and both right on separate outputs. (not for my actual signals, just for non-driving use. Not to activate with my signal switch)
I also wanna try to keep all the wiring near the steering column and dash fuse panel.
My issue,
The front and rear turn signal circuits are separated in the multi-function switch, due to the brake lights.
These are the extremely simple wiring instructions for the flasher.
View attachment 11_1005_11_1005sf_instructions.pdf
What I was thinking of doing was,
*Tie the flasher out puts into the, left and right, front turn signal wires.
*Then wiring a jumper between the front and rear signal wires, with a diode soldered in the middle as to not back feed power from the back to the front, when the brakes are applied.
Sound good?
What I got,
What I wanna do,
My issue,
Sound good?
