- Aug 6, 2007
- Age
- 49
- Berrien Springs, MI
- My credo
- If you can't go through it or around it, then go over it.
I have a evap can/ fuel system leak (the minivan finally started throwing a code and a CEL) and thats what the scanner said. it has to be on the return system because the engine computer says it is getting 19 mpg, but I go to the pump and its closer to 8 mpg. I cannot find any evidence of leakage near the tank. there are no puddles under the car...... strong gas smell from the middle - to the - front of the car I just can't seem to see the leak. where is the evap can? I think I need to start there and work back.
other issue. replaced the leaky steering rack (took 20 min, did it this morning) still leaking power steering fluid...... not leaking at the pump. appears to be leaking at the resovior around the cap, that is the only visible evidence of a leak on the steering system.
was there a service bulliten on the resovior?
99 chrysler Town and Country with 158,XXX miles.
