Whitch starter will bolt up to my fm146
Featured Build Threads
Depends on what clutch/flywheel you used. If it's from a 2.9 the starters are the same. If you "upgraded" to the 4.0 clutch/flywheel you'll need a manual starter from a 4.0.
BTW, later models (Not sure how much. Any 4.0 maybe?) auto starter fits the 2.9 clutch/flywheel and is of more compact design. I used one myself.
I changed my 1990 Bronco II 2.9L from an A4LD auto to the FM132 manual (2WD version of the FM146), and the auto starter was the same as the manual starter.
Upcoming TRS Events
Featured Ranger Based Vehicle
