suzuki2903
im going to install a after market oil pressure gauge on my 99 ranger with a 4.0 but am not too sure where to tap into the engine at? also is a mechanical better then a electric gauge? thanks
Just a word to the wise: The mechanical guage, as far as I am concerned, is much better than the mechanical - especially for an engine that cracks heads so easily when it overheats.
But . . . Run the thermister wire through your mounting, then route it through your motor, and then attach the bulb to the engine. If you leave off the mounting you have to undo the whole thing. Makes youfeel foolish.
sounds like your thinking of a mechanical water temp gauge.
a mechanical oil pressure gauge can be disconnected at the gauge or the engine...so no worries if you run the tubing without the gauge installed in its mount.
