What starter do I need
Aidan_1988_xlt
Forum Member
Sydney Mines
NS - CAN
Vehicle
Drive
235/75/r15
So I’ve asked similar questions pertaining to this job previously but I am swapping my fm146 out of my 2.9 88 xlt to a m5odr2-HD from an 4.0 09. I’ve retained the 2.9 size flywheel and clutch. Am I going to have to use a different starter than the original size one for the 2.9 setup? If so, what one can I use to properly engage the 2.9 size flywheel?
I don't want to steer you wrong...
@Shran
I believe you can use either the one you have or a 4.0 starter from any year. I think I ran into an issue with the block plate one time though where a newer starter didn't fit an older block plate or vise versa - don't remember. The big hole was just a hair too small for the starter to fit into. Just check to verify fitment if you mix & match.
If you use a 4.0 starter you'll need the positive battery cable too, they are wired differently.
And make sure you use a starter for a manual and not an auto. They are different.
That's pretty much it.
There's an article here somewhere on the wiring differences.
But, the 2.9 starter will be fine. No messing with anything that way.
