What did YOU do today?
is it the main panel or a subpannel. Keep in mind....You can't have a bonding screw in the subpanel and the neutrals HAVE TO BE SEPERATED FROM THE GROUND WIRE'S . Meaning , the Neutral Wires can't be in connection with the sub breaker panel.
Sounds exactly like what happened when my parents' house had a bad neutral between the meter and the house.
Sounds like a few of us have experienced this.
Probably. If those voltage readings are at the panel, that narrows it down to the neutral bonding screw in the main panel or a loose connection at the ground rod outside.
Event Coverage
TRS Merch
