What did YOU do today?
More work on the shop….
Today I forgot to put coffee in the machine before turning it on.The first time the coffee looked a little weak, perhaps time to clean the machine. On the second try I forgot to put the pot under the drip... but at least caught that lapse before walking away and coming back to a mess.
You are not alone. No, seriously, look out behind you!
Parts came in for the truck yesterday. went with a bosch starter, thought it was a german company but once again-“made in china”. Got it , new cables & a solenoid on it today & it fired right up. Had to jack up the left front corner to be able to get under it. Starter seemed quite heavy for its size. Looked like all the parts were original, starts really quickly now. Never thought it started bad before but it really hops off now. Drove it to my parents house since I didn’t have a chance to last weekend. Topped off the tank to check the milage, was impressed with it. 17 mpg out of a 4420# full size 1/2 ton. not bad at all.
Random day... went to a local swap meet (you've heard enough stories about me...) and was fairly controlled, just got a couple things until the end when I found a great deal on a Husky chainsaw... I think it's a 257 model with a 24" bar... couldn't pass it up for $100 since I have a need...
Then went to an estate sale and spent some more but got some good stuff, mostly consumables like spray paint, solvent and bar oil...
Once home I mowed some, cleaned the shop some, burned weeds in the shop driveway then just got in from moving some dirt.
Got the pool project finished, supposed to be in the ‘90’s this week so I might actually use it. The umbrella I got for free, guy at work scraps and this was in his truck along with the broken table it went with. zip-tied a pvc tube into the corner & its all good.
Fairly productive day... Went over to my moms to hang out for a bit, then went to Harbor Freight, when I got home I remembered what I was going to get there on their current sale so I went back (annoyingly a 15 minute each way drive), I wanted casters for my welding table so it's less annoying... Their threaded stud caster selection is lacking so I will have to make adapters from 1/2-20 to 10mm coarse... no biggie, I have a plan. Around then I realized my welding cart arrived so I started assembling that. Once that was together I realized it was NOT designed around a 300cf tank :), it could be worse though, it will take at least 15 pounds of upward force to get it tippy and will get better the more stuff I put on the cart...
Somewhere in the middle of that I raked some dirt in the yard to flatten an area out, there's a LOT of sand in the dirt so we'll see how that works later...
