- May 15, 2020
- Age
- 70
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- Vehicle
- Ford Ranger
- 4.0 V6
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
Went to check something on the tractor, its really damp right now in its tarped up kennel “shed” with the temps being so up & down with no sun I expect its going to be damp in there for some time. So I took my escape out of the garage & put the tractor under a better roof, let it run for a good 1/2 hour. Have the blade on the back so if it ever snows its ready to go.
A thought from something we used to do in the old days. Lay a tarp over it, and put some 2x4s or whatever around the edge of the tarp on the ground so it seals it up pretty good. Then put an old-fashioned incandescent bulb trouble light in there. You only need about a 25 or 40 W bulb. The heat from the bulb will keep the moisture away.
I have an ancient metal kitchen cabinet, the white porcelain ones, most of you guys probably have no idea what I’m talking about, but that’s where I keep my welding rods and a couple other things that would be moisture sensitive. I always have a lightbulb going 24/7 under the bottom shelf to keep them all dry. Works like a charm.
