- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
@alwaysFlOoReD I really don't want to hear about a repeat of your profile pic while rolling down the highway. As such, I'm going to reitterate what these two said:
You have a lot to loose from applying the cold steel. Not only is the barrel strength compromised, that crack is going to continue to grow. Applying that seal is going to do nothing except possibly seal the crack temporarily for mounting the tire and getting up to speed. The crack will grow, only way to prevent a crack like that from growing is to find the actual end of the crank (likely invisible to the naked eye) and stop drill it. The only way to reliably seal it is to have it ground out and welded up. With the cold seal allowing you to mount and pressurize the tire it is liable to give out if put under load (simply driving is enough) and cause a massive failure on the road, resulting in a major wreck.
At least this crack terminates into a hole so it's not going to grow. Unfortunately, a lot of the frame around it is also missing. Maybe a good place for a frame repair patch? Weld the crack, treat the rust, and cap with a patch? Only other option is probably attempting to source a frame.
Where do we send the flowers if it doesn’t work?
And you guys were on me about fixing the kitchen chair. Kitchen chair won’t go as fast….,
hate to tell you, but the vertical lip is what gives the barrel it's strength.
no way would I use that wheel. YMMV
Finally got everything as good as it’s gonna get for now with the F-150 and as I was finishing up I noticed something super unwelcome…
