- Oct 7, 2021
- california
- 2.5 (4 Cylinder)
- Manual
- Tire Size
- stock
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Are you trying to get the old fluid oit? Or refill and remove air?looks like a i figured out a setup that may work but now the pump isnt pulling vacuum. this pump was brand new plastic sealed in the box when i picked it up this morning, i even tested it and it worked. the last two pumps i tried to 'rent' from autozone wouldnt pump either.
any ideas whats wrong? i tried moving the steering wheel left to right about 20 times and it keeps bubbling air and if i go really fast, it seems to be sucking in air as it raises the powersteering fluid level to start spilling out the reseviour(sp?).
advice?
So… you should have shot me a text. Might be able to find what you need for the vapor line amongst all the stuff I have. If it’s the same as an 02 uses I should have literally everything.Well, the fuel pump has been replaced but the locking ring for the line going back to the vapor canister broke and the line is a dealer only item. So, I wait until Monday to take care of that. That is going to be a several hundred dollar item.
I went to connect the battery to test the fuel pump and the negative terminal broke. Autozone has a fairly decent replacement terminal that doesn't use the clamp style connector for the cable. So, I guess I'll be getting that.
While I'm out running for that, I'll stop by O'Reilly's and pick up a couple weather sealed single pole connectors for the wire that crosses over from the left tail light to the right tail light for the third brake light logic circuit used to make the cap light work properly. It was hard wired in before and required being cut off so I could get the bed off of the truck. Those terminals will allow me to connect and disconnect as needed in the future. Looking at the condition of the bed, I can see it coming off some time in the fairly near future for rust repair in the usual spots up front and along the right side above the exhaust.
Also, I have a stockpile of Weatherpack and Deutche connectors…
So, I decided I’m tired of waiting to try to get a diff cover and the Choptop needs the locker and here we are with the locker mostly installed in the Choptop. I’ll finish tomorrow. It’s not exactly right, I’m 0.008 out of spec. It’s the shims, they’re apparently worn down. I have a set of new shims and some used shims but they are for a limited slip differential and are not compatible with an open differential. I’ll get new shims and a diff cover when I can and deal with that then.
Send it over when you get a chance. I don’t have the truck here unfortunately, but we’ll figure it out. I have a couple places to look if I don’t have it too.I can take a picture and send you a text on the connector for the vapor line. What you have might be the same. The part is listed as 2010 & 2011 only but we'll see. It could just be tubing length or something else that makes it special.
If you have that, then I can get some Weatherpack or Deutche connectors off of you while I'm there. They only need to be single pole.
What are you looking for in a differential cover? I'm pretty sure I saved the factory one from the 8.8" off of the 2011.
So, I have a stock 8.8” cover now. I was really trying to get my hands on something like a Solid cover or something more substantial than the stamped tin stock covers since this is supposed to be an off-road capable rig and had been putting off installing the locker as a result.I may have a stock one too, from my 04 8.8
