Finally got my 96 parts truck stripped after finally finding someone to buy the engine. I knew it was rotten, I just didn't think it was as rotten as it was... never had a transmission fight being removed as much as that one did
I’ve heard that backspacing is sometimes an issue but should fit
I picked up those four Jeep wheels, they were free. That was to get a spare for. @Peter_'86_2.9L_Auto ’s truck.
The wheels had 31 x 10.5 x 15 tires on them, the heavy duty things that have the three ply side walls. When I measured it with the tape measure, the offset was about 4 1/2 inches and the Ranger offset was about 5 inches if I recall right. We pulled off his front wheel and we tried one and just steered it back-and-forth on the Jack. The wheel fits fine, but the tire is big. I gave him a smaller tire to have it swapped over. It’ll work fine as a spare.
Now I have to get rid of the other three jeep wheels and tires…..
Did I mention I love Craigslist at marketplace?
Drove my 97 to whiskey town lake for awhile. Really needed some nature, i took a few pictures. Will share more when I can get out more to different places.
poured the last bit of concrete on my ramp. buddy towed in a shortbus for oldman in a wheelchair to live in and broke the steering, hope its the bus isnt a 7.3 powerstroke.
then drank an ipa tallcan with the tow driver and continued troweling in the sun, whoops
also sewed some kneedpad inserts
onto my pants
-edit-
whoops, i thought this was the "what did you do today" thread
just prepping projects, looking for seats and there is a "pull it" nearby that has good potential.
front shock insulators...I did not realize the aftermarket shocks don't always snug the top, depending on their bushing size. It's minor, but I can hear a small amount of movement, and the current upper bushing is not nearly compressed enough with the nut bottomed on the threads. I could just stack washers, but I might see if I can find some OE bushings in good shape. Unless you guys have some info I need (high probability this is the case).
Also pulled a pending 0420. So I'll start the process of examining my exhaust. No issues driving, but it's so old tough to tell. I've been searching and skimming old threads here, lots of good info.
Pulled a 503, I think I just maybe jostled the wiring harness under the driver's seat messing with the scuff plate (I'm going to try to refurbish my weatherstrip).
Finally, ordered o rings for pressure line on power steering. Light leak at pump, 95% it's just the o rings and I figure that's a cheap starting point.
So lots of little things.
i have orange coolant in my truck and bought green coolant, what do?
ive changed coolant fluid at least twice in past ten years, (thermostat replacement and then later timing belt) and i figure its been a few years so how about a preemptive fluid change instead of a later flush, so i bought a cheap bottle of green preostone coolant off rock auto. well i checked color on 2 or 3oz of fluid in my truck and it is a light yellow (orange?) do i need to flush my current coolant to use this green stuff? or i could just pawn off the green coolant to a neighbor..
now that i think about it, i did timingbelt in 2022 ...not that long ago
What does the green jug say? I buy cheap stuff at Walmart or the AutoZone, but I only buy the stuff that says “all vehicles.“
Number two, look at the specs in your owners manual. If you don’t have the owners manual, you can find it online.
Drove my '93 XL with WAY more than 300K miles on it after a ICM change, found an issue, and came back to the forums looking for answers, found that apparently my last post was in 2017. So posted my issue, posted my location, and commented here, realizing eight years flew by, and none of my projects on MY vehicles got worked on, and all the quick improvements for the '93 are still stacked on a pallet in the barn, the last time I welded was making a quick 3-point log skidder frame right after Helene, and box for my "new" 20-ton HF press has completely disintegrated a long time ago, but at some point I converted my first 20 ton press to air over hydraulic.
:icon_confused:
And like the run-on sentence above, apparently my life has been in a run-on phase.
I'm with @pjtoledo on this one. Welcome to normal, at least for this place.
If it makes you feel any better, I'm got a Harbor Freight 20 gallon compressor and shop pedestal fan out back that are both in the same condition. New in box under the carport where I put them years ago. Or at least in what's left of the box.
Bought the compressor several years ago because my former one, also 20 gallon HF, died after many years of neglect and weather exposure. Months later I hadn't needed to unbox it yet, and dad found a hidden circuit breaker on the old one. Reset breaker and the old one went back to working, an dI never had need to unbox the new one. Since then I bought a second hand 60 or 80 gallon tank with a new pump and bad motor that we fixed. The new 20 gallon is still there in the box.
The shop pedestal fan and a shop "box" fan were both bought a couple of years ago when I was going to clean up the carport and start a couple of projects under there. The "box" fan made it into a corner of my living room where it still resides in the box, and the pedestal fan made it to the carport.
Hopefully all of the above will actually work when/if I unbox them.
Yeah I'm constantly int he run-on phase of life too.
It's got all these features that I have no idea about and there's no owners manual to tell me. 😱
It's in the radio. Yeah, I don't understand it either, but it's apparently in there. Dad bought a '21 F-150 new off the lot and it did not come with a physical copy of the owners manual, it's buried in the infotainment center in the dash. It was anoying to him and now that I have the truck it's annoying to me. No excuse for not having a physical copy. If the truck isn't getting power dur to a fuse, I can read a physical copy, I can't even look at the digital one.
That is one thing I hate about the used vehicle market. It's a crap shoot on whether the vehicle comes with one or not.
New ones don't even come with them now, at least that '21 F-150 didn't come with a physical copy. Hopefully they've corrected that mistake and are shipping them again.
Yeah I was going to say that buy looks like you figured it out the hard way. The older Jeep stuff (some of it) has the correct 5x4.5 lug pattern, but less backspacing than Rangers. It fits, but sticks out further than the Ranger wheels, and that isn;t always a bad thing.
You do have to watch it on the aluminum Jeep wheels. The pattern and backspacing are both same as steel, but the center bore is too small on at least some of them.
Did it develop the munchies too?
Did you change it, or did you have it changed?
I'm going to assume the latter since you were not aware that it was the orange/yellow stuff. If you paid someone to do it, there is no telling what they may have put in the system. The coolant that Rick mentioned claims to be compatible with all, but there are some coolants that react badly to different to being mixed. It may be safer to do a flush and change to avoid any potential bad reactions.
If doing it yourself, you aren't saving that much money by doing a drain and fill instead of a flush and fill, mostly saving time. You don't really need a chemical flush unless it's contaminated, just need to clear out all of the old. If it were me, I'd drain the system, fill with straight water, and drive for a bit to circulate and mix the residual well. Some would suggest using only distilled water in your cooling system, and that is best, but I'll use tap depending on local water quality. Repeat a few times and you'll have practically all of the old coolant out.
After flushing do the following:
  • Drain system as much as possible/practical. I'd pull the bottom hose too.
  • Add with required amount of straight coolant (not 50/50). If cooling system capacity is 10 quarts, use 5 quarts straight coolant to get a 50/50 mix when finished. Your owners manual should have capacities.
  • Fill the rest with straight water.
  • Bleed cooling system, and top off with straight water again. (IMO a cooling system bleed funnel is worth buying)
Reason for doing this instead of filling with 50/50 is that is is impossible/impractical to completely drain the cooling system. As such when drained you will have residual water in the block and heater core. If you add 50/50 your resulting coolant will have a different ratio once mixed with the residual water int he system. Since you've flushed the system with straight water, the adding the proper amount of straight coolant and and topping it off with water will give you pretty close to the desired 50/50 coolant mixture.
It may take a few days of driving for all air pockets to work out of the system, and for those subsequent top offs you will want to add a 50/50 mix to avoid diluting the coolant.
Hopefully that made sense instead of adding confusion.
Yeah, I'd agree on just starting over, then figure out what's supposed to be in there and use that.
I was always told that you could mix coolants of the same color. Of course, with some of the new coolants, that isn’t even a safe bet anymore.
I wouldn’t mix green coolant with anything but green, universal or not.
I’ve gone to using the universal orange stuff anymore. Haven’t bought green in a lot of years.
I know with Japanese cars, there's green and blue, and they can be mixed. I think the blue is longer lasting. Downside, it kind of turns it "brown" lol. I think it's all about that POAT, OAT, HOAT, PHOAT, etc...no clue what it really means but like for like.
Ordered just under $1100 in parts for the engine swap project.
Oil pan/pickup/pump, water pump, fuel pump, timing chain/sprocket kit, transmission shift kit, bunch of filters/gaskets and seals.
Theoretically, there is very little left to buy other than exhaust system piping and drive shafts.
I experienced the Honda green and blue. I never mixed the two but I have used both. Green was first, if I remember correctly and then it got phased out for blue.
Yeah, just got a Mazda. Same. The factory is green, but the blue is "better". I think a newer Japanese car would probably have factory blue.
