NateWollzie
Hello, Nathan here.
I have a 1988 ranger and I ended up acquiring another 88 that had the power locks and windows... So I unhooked the battery... Then popped out the lights, horn and plugs on driver fender... Out with the old in with the new.. and this is where I messed up...
So in the process of connecting the auto locks/windows wiring harness to the starter solenoid, somehow I managed to either ground the positive or vice versa on the solenoid... Sparks big enough to make me turn away.. leaving it longer than anyone would ever want too.. and add this, the truck no longer starts... Or will even crank over...
I have removed the harness, re installed the original.. I have an extra battery and tried switching batteries, no change, I replaced the solenoid, I'm getting power to the pumps.. still no change when I bypass the starter relay or ecm.. whatever it does lol.
I changed the cable from the battery to the solenoid..
Replaced the battery cable clamps and cleaned battery terminals.. checked engine, chassis and starter ground, and grounds under the hood.. fuses under the dash, on the driver's side) all look good..
I'm getting 12v off the battery and power off the solenoid and relays.. could I have fried my starter or something like that?? I know I'm missing something! PLEASE HELP!
