well to start off i did a 5.0 converson from a 1998 explorer to my 2000 ranger
big mike lott
1211 Marks Ave
3 in supension 2 in body
35 x 1250 x 18 nitto grabbers on custom wheels
well all went together fine now to the problem i powered her up today all went fine tull i tried to use the remote entry key farb the unlock lockes it and the lock does the reverse if what i just said im puzzled on this one in drawing a blank ?????
any thoughts would greatly apreatued thanks mike
Welcome to TRS :)
So you are using 2000 Ranger Keyless entry Fob?
This Fob operates the RAP module which tells GEM Module to lock or unlock the doors
Does the door lock/unlock button work OK, not Reversed like the Fob?
2000 Ranger key Fob programming
DO NOT depress brake pedal during this programming procedure.
Unlock all doors using the power door lock switch on door panel.
Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door locks will cycle to confirm programming mode.
Within 20 seconds press any button on first keyless remote. Door locks will cycle to confirm programming.
Within 20 seconds, press any button on second keyless remote. Door locks will cycle again to confirm programming.
Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
sorry did not give enoughf info we did a swap with a 98 explorer engine tans wireing diff
no im useing all electronics fron a 98 explorer i have not tryed the door switch wet will do so shortly
the inside sw when you press unlock it lockes the truck
pass side door not wired yet i still have to strip that door thanks mike
Easiest fix would be to reverse the 2 wires on the 2 door locks, either repin connector, or cut and splice, reversing the 2 wires
Ranger and Explorer probably use opposite polarity on the door lock solenoids, you could try moving over the explorer door lock solenoids to the Ranger but not sure if they will fit and seems like a lot of work vs reversing 4 wires :)
pasenger door harness swaped lock is backwards everything works fine
ok on further testing the power door lock units are different on the ranger than the explorer they work backwards on the ranger so just switch the wires all good
tthanks for the help Big Mike
