- Jan 7, 2016
- 1969 f-600hd
- Automatic
my 91 4.0 wont idle now hardly at all now but starts up fine and seems to run well down the road This was after i put in 3 gal out of a can that i think may of had about a cup of rain water at most, then let i let the truck run completely out of gas.. Then i added 5oz of seafoam to 5 gallons of fresh gas and half way through it now i still have the idle issue.
And Now i hear a massive vacuum leak coming from from vacuum T boot from what i"think" [cant see it] goes to pressure reg via plastic line down behind engine...
The boot seems to fit snug, its almost like either theres to much vacuum or the line is blocked..
ac is blocked off
cruise work fine.
brakes fine
Its possible there wasnt any water in the gas to start with and because i just noticed or heard the vacuum,, i dont know.
I havent disconnected battery,, could it be an ecm problem with system trying to figure water in on the mix?
What yall think?
ac is blocked off
cruise work fine.
brakes fine
What yall think?
. chessman2121 at gmail
