Can explorer drum brake axles & just the side gears from the carrier be the only items needed to allow the use of the 31 spline axles in my 8.8 that's from a 99 Ranger 4.0L/4wd?
Im unsure if the explorer shafts will fit into the tube area as the explorers are to be wider. Or is this width from the tubes out to the wheel mounting surface. Example longer shafts , not longer rear end housing
May even be interested in swapping the disc brake set up from an explorer to my Ranger 8.8 so i would just as well get the complete disc set up & the side gears & axles.
Any info would be greatly appreciated.
Thanks guys or gals
Thanks guys or gals
