So what I have read you can put disk brakes on a 7.5, all I need to do is find a mustang from 94-04. I have seen a few in the JY near me. And this setup will also bolt to an 8.8 28 spline too.
Same here finding a 95+ exploder in local JY isnt going to happen anytime soon as they have older vehicles in there but have plenty of older exploders there with the 8.8 28 spline and a few mustangs that may have the rear disk brakes. I see this as after blowing up the 7.5, just put the disk brakes on the 8.8.
While were discussing this with people who seem to know.The Explorer is 3" wider than the pickup rear axle it says in tech.I was thinking the B2 is a little shorter like 2" shorter than the pickup.My tires are going to stick out 2.5 inches on each side something like that.When you measure it it hangs down lower at the pumpkin I measured about an inch.Which makes sense cause the ring gear is about an inch bigger.The Explorer rear end is much better tougher with more after market support.Ad to these things the cost and work to make the ratio match the one I'm happy with.Every one will probably think I'm an idiot I don't feel I need the extra strength for what I do unless something changes not worth the sacrifice.But I really like the idea of putting on brakes.
I'd check into that kit, think it's meant for the larger Cobra brakes that requires 16" rims. It shows the 11.65" rotors while the stock GT uses 10.5". TeddyZee did the swap on his truck. I think RockAuto has some good prices but it's been awhile since I looked.Found this on ebay and the price seems right to me, may do this instead of going to a JY for the setup....
http://cgi.ebay.com/ebaymotors/Ford-Racing-Mustang-GT-Rear-Brake-Bracket-Kit-M-2300-M-_W0QQcmdZViewItemQQfitsZYearQ3a1994Q7cModelQ3aMustangQQhashZitem5ae0e2460eQQitemZ390319982094QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Dave of the Nord
Think that's about it, just too big with the smaller rims. Other than that, that's a good price. Think the Cobra calipers work on the smaller rotor but I's sure have to go back and check. It might be covered in that link I posted.So what wont work in that kit, just the rotors?
