C5 Transmission, missing block spacer plate ??
A rubbing of the bellhousing pattern with the part you have left overlaid and added to that should be enough to make one. The right thickness steel, a jig saw, drill bit set, and a carefully selected hole-saw should do.
It looks like E3TZ-7007-F.
  • C5 Transmission, missing block spacer plate ??
Well done Andy B! It does appear to be the correct part number you found! Still don't see a single listing anywhere on the interwebs for such a part....but I do appreciate you taking the time to find that and post reply. I'm still searching around, and perhaps I'll find an image of said part, so I know what the complete part looks like, compared to my fragment. That would help me in creating one. Thanks to all that helped on this. I think I will be doing a tracing/rubbing of actual housing, creating new spacer as some have suggested to the best of my ability, and pray the starter indexes correctly.
