Updating the 2.8L Tech Page - Suggestions Needed
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
I want to update the 2.8 Page in the Technical Library in the coming month(s).
The page is a few years old and I'm not sure how accurate the info is anymore. If you have ANY suggestions as to what should be added, changed or deleted from the page, please post them here. This includes part numbers, names of manufacturers, links, custom modifications, know problems or even cheap tricks.
Thanks.
86 aerostar 2.8 stock headers and y pipe
tubular exhaust manifolds off early aerostar with2.8 and y pipe lists same as 2.9 aerostar - good cheap mod
The Racer Walsh site doesn't link and maybe should be dropped. They don't carry the line that they used to. They used to be a great source for 4 cylinders and the V-6.
Actually Racer Walsh still has a little stuff for the 2.8, particularly the offy intake. Biggest thing is there site address has changed. Actually by doing a quick search of the site they still have all of the stuff listed in the tech page.
Pacesetter, Hooker no longer carry headers. Hedman does still makes them, and IIRC so does Eldebrock.
THose are just what I got at the moment.
When removing and reinstalling the front timing cover there's two water passage sleeves that have to be replaced sometimes. These are actually called "Bushing Water Inl. Cly Block" Ford part#D2RY6178.B These have been discontinued by Ford. There's only 10 dealers in the U.S.A. that have some. And that is only a total of 23 sleeves. They can be made out of steel if your really hand in the shop.
The screws can back out of the rotor and it will come loose and destroy itself against the cap with the stock distributer, it has happened to me and at least one other user.
The first thing that you think of is the cam/crank gears died, mine had a really nice backfire that blew up my muffler when it happend.
Maybe a general tip page is needed for various things
The disintegrated rotor thing happened to me too- something to watch - I now use just a touch of Locktite on the screws.
Also carry a spare TFI; I had one fail in a city intersection - about 6 hours and almost $300.00 to get back on the road. Could have done it myself faster and cheaper.
the rotor button??? When i bought mine it had cracked the distibutor and was all beat up laying inside...is that commen or something, and if it is what the hell happened at ford when they made that?
My guess is they figured people would check them occasionally (back then people still did regular tune ups) and it would be replaced/retightened.
I must admit that was the first time I had looked at mine...:black_eye:
I know this is old, but I think the tech page needs a write up on replacing 2.8 valves with valves from the 2.9
I ve got a procedure for installing front crank seal on 2.8 so that it NEVER leaks, you know they all do! soon as I can get pics, happy to share!
If you update the duraspark upgrade page for the parts list, you can get the dist. cap adapter at autozone. It's part number F976.
It's listed in the computer as a "distributor cap & rotor kit." Yeah -- it took some quality time to find that one.
more tranns swap info. and aut to 5 speed info as well
pics of duraspark wireing, how you connected it, where you ran the fuel lines
for lack of a better term
Duraspark for dummies(not that i know anyone who would need that....)
and that seal mod would be a great addition
