Uneven sides after skyjacker lift kit 4in
Featured Build Threads
Colton - 94 Ranger
Forum Member
Washington
Hey everyone, I recently did a 4 inch lift kit on my 1994 Ford Ranger, after it was all set and done, I had an alignment done and noticed that the driver side seems to be leaning and the passenger side seems to be about where it should be. Is there any reason as to why this could be? I do know that the coils see differently on each side, which is why I would think that it should still sit evenly?
I measured out from the ground to the middle of the fender, and these are what I got
Passenger:
Front 37.5in
Rear: 36.5in
Driver
Front: 36.25in
Rear: 35.25in
I’m just a little confused as to why this could be. I’m 99% sure everything is right, but any insight into somebody else that has had potentially the same issue and what you could do to resolve it would be appreciated. I did think about stacking washers on the driver side, but I just had an alignment done and I thought that may fix it. so I’d like to try and not do that unless I have to. I guess that’s what I get for trying to lift a TTB.
that's just the ranger lean with the fuel tank being on the driver side. it could also be that your body mount bushings are worn out
This.^ Exactly 3/4 in. lower on drivers' side sounds about right to me. Especially if you have a full tank.
Life is not a perfect experience, then your Ranger leans after you install a lift.......
Pretty normal, mine leans just looking at a pretty girl! A crank on the coil and life is good again, but my neck is stiff now~
Moving this to where it belongs…
Featured Ranger Based Vehicle
