any body have knowledge of how to not only change caster/camber pieces. but to also know how to determine which kit or pieces are needed to correct alignment?.........also want to lift front end with taller springs, current spring ht. under load is 12" give or take a bit. if i do spring swap which shocks are needed. Only looking for about 1.5" or maybe 2.0" lift if possible.
For two main purposes going with a 15" tire and also the stance.
