Turn signal & hazard fuses
westtexasbaja
1994 Ranger supercab 4.0 auto 4wd:
Left turn signal works fine.
All Bulbs are good and have been removed for testing.
Right turn signal and hazard button both pop fuses when used.
Rigged up a 20amp breaker in place of fuse to help with locating short.
When right turn signal is used, dash indicator barely blinks and is very dim and dash volt meter moves with every blink.
When hazard is used both indicators are dim and do not flash. They stay on until breaker trips.
Any help welcome. Thanks
Found the short. Roll cage had rubbed a hole into the engine harness. Wires were shorting on the bare metal. There was nothing wrong with any of the lights or multiswitch.
Thanks for the fix post.
I didn't see this when originally posted, I would have suggested trailer wire connections, I would have been wrong, lol.
