Turn Signal And Hazard Light Problem??
86bduece
10+ Year Member
Okc, OK
Neither My turn signals or hazards work. not on the instrument panel either.
They Worked When I Got The Vehicle. But The Next Day Nothing...
Ground
Mine did this, though it was intermittent, when the ground was ungood.
All else fails check for voltage and ground at every wire starting at the bulb and working back. Most likely I'd guess it's either the switch in the steering column or a bad ground... If they're both failing it's probably not the relay (flasher)
Check fuses first.
