MikeInARanger
- Dec 11, 2014
- Automatic
Hey everyone first post here. I just picked up a heavily modified 94 4.0 ext cab 2wd prerunner AT. The A4LD is barely hanging in there, slips in lower gears when cold and overdrive is gone. Instead of replacing the trans I would like to throw in a 5.0 and I'm just trying to figure out the best donor vehicle. Trying to keep it smog legal here in CA. I've had my eyes on a 95 mustang gt I found on craigslist because I wanna use the T5 and also avoid dealing with the p.a.t.s. on newer explorers. I've read enough about exhaust manifolds,oil filter relocation, motor mounts, crossmember relocation, and setting up the clutch.
What modifications will need to be done to the two-piece driveshaft in order to mate it to the t5(yoke splines driveshaft length) The previous owner said the 8.8 was at 4.10. has 33inch tires
From what I have read the wire harnesses for the 94and 95 is a pain in the a$$ to set up without a special manual. Is the frankenharness possible? and will it smog?
I have big plans for this ranger and could use all the help I can get. Thanks in advance.-mike
