sbsumerix
i know with having a truck from 94 it needs some repairs every now and then. but i decided to put a good $250 into it with cab mounts, ball joints and fix the leak in my exhaust and now my truck is deciding it needs more attention. i have a leaking steering gear box, the seal on the sector shaft were the pitman arm attachs which is getting really bad like a quart a week unless i put lucas in it. also it now has a brake leak in the rear i see it on the rear axle not sure if its the line to the passenger brake or the line going into the t-block. i hate when i go to work on it and then more things go wrong.
