Hello pals
Here is my story… more than 3 year ago I moved Tires size from 235/60R15 to a all terrain 31x10.5R15, then I run into speed issues due the tire size change
, I asked for some advice and it was that I had to swap the Axle, so after a hard time looking for the axle I swap it from a 7.5 to a 8.8 Ring Gear diameter and problem was partially solve although not at it should be but I have living with that for the last 3.5 years... Now is time to replace the tires but this time I will like to have a smaller tire size but keeping the same rims size 10.5xR15 so I went to a tire store and they told me that the smallest size it could fit it’s a 275/60R15….
Now after the entire tragedy novel I have described, My doubt is as follows; if I move to a smaller tire size, do I might run into speed problems again due this time now I have a 8.8 axle? I’m assuming that I must not but better have first a good advice, and the other it’s really the size 275/60R15 the smallest size I can fit in a rim 10.5XR15? question is because the guy in the store told me that they do not usually have that tire in stock but of course he was just trying to make the sale but just want to confirm
Well hope you can give me a hand on this instance
Thanks in Advance
Thanks in Advance
