SuperDangerRangerXLT
- Jan 30, 2017
So I have a 1990 Ford Ranger with a 2.9l V6 and a FM132 transmission currently bolted to it. Truck is 2-wheel drive, but the tranny is shot. I have an M5OD-R1 from a 1991 3.0l Ranger and am curious if the swap is possible. The yoke on the old drive shaft shaft is slightly too small to fit the newer transmission, so would a yoke from a driveshaft off of a 3.0 motor match the U-joint? Also, would the starter from from the same 3.0 motor work on the existing flywheel from the 2.9l? Still haven't checked if the tranny will even bolt up, just looking to see what is possible wit what I have already.
