Transmission Swap Automatic to Manual
Battle Ground,Wa
I have a 2006 Ford ranger with a 2.3 RWD and i want to swap the 5R55E to a M5OD and was wordering if anyone could point me to a thead that could give me a little help. Thanks..
Well the one main conserned i have is wether i can just bolt the transmission up to the back of the engion or if i have to get a diffrent backing plate or something along those lines. I now the rest its just that part im having trouble with.
M5OD transmissions have an integrated bell housing so you will need an M5OD trans from a 2.3l Duratec Ranger RWD, 2001 or newer
Rangers used 2.3l/2.5l Lima SOHC engines prior to 2001, in 2001 Rangers got the more powerful 2.3l Duratec DOHC engine, these engines are unrelated so their transmission are not interchangeable.
You also need the Flywheel from 2.3l Duratec engine, I think starter motor is the same but you need to check that.
Automatics use Flexplate to power torque converter
Manuals use Flywheel to power clutch
Starter motors engage the Ring gear on the outside edge of flexplate or flywheel, on some models the ring gear is at a different depth or height, so starter motor model is different.
Just look up the replacement part, if there are different part numbers then you will need to change starter motor, wiring will be the same.
You also need manual transmission computer or have your computer software changed to manual, this also effects the PATS(passive anti-theft system).
Automatic computers need to be hooked up to the transmission or they will report a problem, CEL comes on all the time.
Not sure about the drive shaft length.
thanks mine dont have the anti theft system and i can get the computer done and the drive shaft length is diffrent i have checked that.
