sdasher1982
so, im in a spot here, i have a quoted price of 750 to redo the transmission(clutch, pressure plate bearing and slave cylinder.) and what not, my question is, is it going to be something other than the throw out bearing. issues are,
1. when i put the truck in reverse hear a wierd noise that sounds like a loud rattle kinda like a couple pennies in a coffee can as you swirl the can around.
2. The truck after a period of driving its hard to shift into gear, esp. after highway driving. the car is really hard to go into first from neutral.
3. Sometimes as i'm shifting through gears the trucks makes like a whining or whirring noise, and the gears rake sometimes as well.
does that sound like that is could be a clutch throwout bearing issue or could it be with the internal gearing it self?
any help would be appreciated thanks!.
