- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
Got a bit of a head scratcher here. I've been around long enough to know to check the tech library. I did, it didn't help.
1999 Ford Ranger XLT Extended Cab 4x4 W/ 4.0L Auto and factory tow package.
According to the chart in the tech library my truck should have a 5R55E due to being a "1998-2011 4.0L Ranger". Per the chart in the tech library my door sticker would agree with this as it has "D" for transmission code.
Several years ago I had the transmission rebuild by a very good, very experienced local shop. When I got the truck back and looked at the receipt it had 4R55E on the receipt. I asked at the time because even then I thought it had the 5R transmission, but they assured me that it was definitely a 4R trans. Those guys are good at what they do and it was working good so I thought no more about it.
The same transmission ID article also shows the bolt pattern for the transmission pans. I was just under the truck an hour ago for some other work and the pan definitely has 18 bolts as shown for the 4R transmission.
What's going on with my truck? Could someone have swapped in a 4R55E in the past and it still function right "missing a gear"?
Is the tech library wrong about pan bolts and 5R55E have same pan as the 4R55E? (<< my guess) Is it wrong about trans code and they were still installing the 4R in 99 (06/99 build date)?
If it is a 5R55E and trans shop rebuilt it as a 4R55E, would/could that cause any issues that aren't throwing a code? I never drove the truck when it was new and it was rebuilt due to wear and slipping. As I found out not long after buying it, the previous sucked at maintaining it, so I didn't really have a good baseline to compare before and after rebuild. Closest I can get is my dad's '02 4.0L 4x4, it always had a firmer shift, but it's also newer with a different engine and different tuning.
On similar note if my truck did somehow come with a 4R in '99, would it be possible to swap in a 5R and have it work right?
I'll probably be installing a new engine next year (please don't ask) so it would be the ideal time to swap in the correct transmission or upgrade to a better one.
Thanks!
Thanks!
