Tranny info
Loneranger91
ok im getting a 85 bronco2 from my grandfather and it dosnt have a tranny and he dosnt know anything about it so im trying to figure out what tranny I need to get for it
On the driver's door label it should tell you a transmission code, depending on the code here's what you need:
1985-1987 Toyo Koygo TK5 (Code 5) 5-Speed
1985-1987 Mitsubishi FM145 (Code D) 5-Speed
Just an FYI I found this on the bronco 2 section of this site up on top the Library link in this section you will find a ton of info on the bronco 2. I just picked up an 84 B2 a month ago, its in pretty bad shape body wise but after a few little engine and carburetor tweaks it runs awesome.
Cool thanks for info by any chance does yours have striaght axle
The only axles on the stock bronco 2's were the Twin Traction Beam style. For what my Bronco 2 is ever going to be used for its good enough for me.
