gstuartw
I am considering using a tow dolly to move my 5 speed Bronco II 400 miles and need to know what needs to be done prior to avoid damage.
Thanks for your help,
Stuart
Stuart
If it is manual transfer case simply put that in neutral and leave the transmission in a gear (any ol gear will do), if electric transfer case there isn't a neutral setting from factory so it's easiest to pull the rear driveline. The transfer cases have a oil pump driven off the rear output so it is safe to tow them in neutral unlike a lot of transfer cases on other stuff...
Yes, You'd be counting on the pin in steering column to keep the wheels straight (the ones that the thieves can overwhelm when stealing your RBV) Pulling backwards puts significant negative caster on the axle, putting lots of load on the pin.Would it be a bad idea for him to back the Bronco on so he doesn't have to remove the shaft?
Eat your wheatiesBiggest thing is getting the driveshaft bolts free. Ford used yellow locktite on them, the stuff that says requires heat to remove.
My concern (other than liability in the event of an accident) is am I pushing my Explorer (with 189,000) too hard?
U-haul requires that the towing vehicle weighs 750lbs more than the combination of dolly and towed vehicle. Tow dolly weighs 750, Bronco II is listed at 3,500lbs, Explorer is listed at 4,500lbs. So, by U-haul's calculations, you're 500lbs too heavy. So, its only partially the hitch, and more the weight of tow vehicle that is issue.Thanks all.
Since I will need to reinstall the driveshaft at my destination and won't have the place or tools I might look into a trailer rather than a dolly. The rig I'd have would be my 2011 2wd Explorer with towing package and 5,000lb hitch. Problem is that when I enter that info and the Bronco as the trailered vehicle their calculator won't allow me to go further in the rental. If the rating was listed as 5,500 it would be permitted. So it seems there is a 500lb discrepancy I'd need to work around. I can portably list the trailered vehicle as something else (Escort or such) and rent. My concern (other than liability in the event of an accident) is am I pushing my Explorer (with 189,000) too hard?
For short drives with manual front hubs it’s acceptable to leave the manual transmission in neutral with an electric T-case. Actually, as long as it’s in 2wd it shouldn’t really hurt anything with a manual in neutral. Pulling the rear driveshaft or having a manual T-case is ideal though.
That said, I have towed autos with auto t-case in neutral but it’s not recommended, there’s a good chance you’ll damage something.
I didn’t say I couldn’t get it free, I’m just saying that Locktite says yellow “requires heat” to remove. Usually a big breaker bar or my Milwaukee impact makes short work of them without heat.Eat your wheatiesI have a good 12pt impact socket along with long breaker bar that's never needed heat. And I put them back with lock-tite red.
Countershaft isn't turning with transmission in neutral/engine off. So, your rolling the dice that bearings have enough oil as none is being splashed up.
