quasi is correct on that stuff. One thing to add though is that just plating the LCA in will still not be strong enough for the coilovers. you are focusing all the truck weight on one little point on the LCA that was not ment for that. you will need to strategically place stripped sections of flat stock in between the lower plate and upper plate in the arm to keep the arm from bending. without it, the first jump/bump you hit, the arm will fold.
getting a 10" shock will be way over kill for your truck and you may find its way bigger than you thought. you will have to relocated a bunch of stuff under the hood to make those fit. I really think a 8" shock will be plenty for you.
Also, make sure that you make some sort of engine cage to connect the LF shock tower to the RF shock tower. W/o this you can easily tear the frame from all the extra leverage from the shock towers.
Unless your ball joints have play in them, you really dont need to replace them. just watch your full droop and full bump and place limit straps and bump stops accordingly.
One thing to remember, travel numbers out of suspension mean nothing if your shocks are not valved right let alone, you can hit just about anything a truck with huge travel numbers of front travel can hit. As i tell everyone i talk to about this, the old total chaos 1450 truck had 13" of front travel and it beat rangers, chevys and other toys left and right all because the front suspension was perfectly valved along with the rear. valving in a truck and make or break how fast you can go and what you can hit.
