sneakyd1
Getting ready to switch my aftermarket wheels/tires back to stock for winter. Can anyone tell me how to reset the tire pressure monitor light. Don't want to look at it all winter !
You need a Ford TPMS reset tool. You can get them from Snap-on or the dealership. I think they run about $25.
Then get in, flip the key to run and back off 3 times ending in run, hit the brake once, then cycle the key 3 more times. Horn should honk.
Then hold the tool to the tire and pass it back and forth 180* away from the valve stem. Horn will honk as each sensor resets.
If you just adjust the pressures you can normally just drive it, but after sitting the sensors are asleep and probably won't wake up on their own.
Wow, talk about a complicated system...why not just keep honking the horn till the sensors wake up?![]()
Now that's some funny stuff!
But, I just upgraded to E rated tires on my 150. Can I raise the threshold setting on that TPMS so I can run 80# in the tires? Is there a range that the monitors allow? Does the TPMS warn of low pressure only, or high as well? How does this reset tool work?
Ya, I know, it's not my Ranger, but I can't get anyone to reply on this on any 150 foroum, and have done a search elsewhere.![]()
Put all the sensors in a sealed PVC pipe with a valve stem. Inflate to factory pressure. Throw it behind the seat and never worry about it again.
