Service_Bed
This is my '88 2.9/5spd. Something blew out the trans and shot a hole in the casing while going 90 in 5th a few mornings ago.
So the two bright holes are in trans and where the mounting bolt broke a chunk off block where they kith
Have to grab a good used eng/trans and do a back alley swap, but while l've got everything out, any tips on what else to do while l'm able to access everything easily? Plan so far is to do -valve cover gaskets, -oil pan gasket -rear main?
For trans what should I get outta the way? Clutch and slave? Budget is a bit tight so might wait on trans stuff seeing as l have the aforementioned gaskets already that I was saving for my old motor, as well would like to possibly install motor and trans as one mated unit? Also would it be easier to add my 4" RC lift with everything out? It's my daily work truck but fortunately a buddy let me borrow his extra car for the time being. Just want to optimize time while everything opened up. Also anyone h a good used 2.9/5spd in SoCal?
