Condensor removal tips and tricks?
1994Fivespeed
My AC has been gone for decades, so I removed the compressor and some lines. Im going to attempt to remove the condenser. Any tips or tricks to make this easier? Its a 1994 4.0 manual.
Not sure how different your is with the 4.0L. I have a '93 with the 3.0L. I removed the fan and clutch (was doing e-fan conversion anyway). Then remove 2 bolts at top of radiator. That allowed me to move the radiator towards the engine without disconnecting its hoses. Remove 4 screws for condenser and carefully lift it out. Getting that fan out of the way makes everything on the front of the engine easier.
What belt did you use to replace old belt ,and how do you get the box off the firewall . Thanks
