Off Road SHO
- May 28, 2010
- Automatic
Well dang, it's not the valves. I borrowed a leak down hose tool and pressurized number 3 cylinder and I don't hear any air coming from the intake or exhaust, but I hear a LOT coming up through the oil drain back holes in the head. I either have a hole in that piston or the rings are totally shot.
I might not have gotten enough oil into the cylinder when I did the first compression test (in hopes of determining if the lack of compression was from valves or rings). I just pumped a good 4 or 5 squirts of Marvel Mystery Oil and will let it sit over night, just in case it's a stuck ring or two. I don't have a borescope to look down into the cylinder.
Another odd thing I found was a spark plug with two longitudinal splits in the upper porcelin insulator. Unfortunately, I don't know which cylinder I pulled it out of, or if it didn't crack after I pulled them out.
If this ends up being a bad piston/cylinder/rings, I am not going to mess with it; the truck is just not worth it.
Tom
Tom
