- Dec 6, 2007
- Automatic
I went from 265/75r16 AT's to 255/70/R16 highway tires and picked-up some power. There is less rollng resistance with a highway tread pattern, they are slightly narrower and smaller in diameter. It was a change from 31.6" diameter to 30.1. That is like changing gearing by 4.7%. That's another way to look at it, 4.10's become 4.19's. That results in more torque to the ground! I also get a little bit better mileage.
Go the other way from 225/70R15 to a 265/75R16 or 27.4" diameter tire to a 31.6" tire, a 13.2% change in diameter. Your 3.73's are now more like 3.23's and not likely to drive your rig effectively. Ford knew what they were doing in selecting gearing and tire size for each engine and truck combo for efficiency. Adding large tires without a gearing change just won't allow the engine to work in its operating RPM range and reduces efficiency. Assuming stock power, 265's with 3.73 would require a gearing change to 4.22. That roughly 13% less torque to the ground is noticeable! The gears available, 4.10's would be slightly higher than needed, 4.30's slightly lower, and 4.56's considerable lower (but may be necessary for large heavy tires). Even if you get the gearing right, mileage will suffer because you are turning a larger mass.
This site has a great tire size calulator: http://tire-size-conversion.com/tire-size-calculator/
Tire width, inflation and tread type effect rolling resistance. Rim material and size have effects too.
I know I haven't covered it all, please add your comments, I posted cause looking at the percentage change in gearing helped me see the effect better, the light bulb popped on when I looked at it this way.
