RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
- Mar 15, 2009
- Automatic
After over 2 years of researching and about a year of parts collecting, I am finally starting my 97 explorer V8 swap into my 96 ranger 4x4, SVT. Since this seems to be an oddball combination, I will be doing a complete writeup since there is none. There are writeups for prior to 95, and after 97, but not really any info for 95-97 swaps, so this is mine. I am performing a complete swap including factory AC
What I know...
The motor, harness, battery harness, AC lines, PS pressure lines are needed from the donor. The motor mounts probably won't fit, as the 95-97 and 98+ mounts are different, but I have a set or 71 ford mounts I'm pretty sure will work, I know they work on a GEN 1, guessing they should for GEN 3...I did find out the AC lines going to the condensor are different styles, to make things easier, I will also swap the condensor from the explorer. AC lines from the AC compressor line up perfectly with the dryer, exact same spot. Low side AC compressor line goes to condensor...Heater hoses are cake, they are in the same spot. I'm not using the factory mechanical fan, i'm going with Taurus 2 speed E-fan, have the fan, but got to get the controller kit. To ease future removal of transmission cooling lines, I'm changing the design and going to AN style fittings on both the trans side and the rad side, will also add an external cooler AND external filter for ease of servicing. Same on Power Steering lines, will get a cooler and filter ( have almost completely redesigned the PS system, added 2 more units and almost a gallon and a half more capacity [I'm gonna need it!] ) Will be fabbing a custom trans mount in prepps for stage 2 (SAS) I will use the exp auto trans and for now the exp Tcase, I have several options, including building a 2 speed case out of the AWD exp case, swapping a Dana 20, using the ranger's 54, or a combination of these (READ - Doubler
What I don't know...
The evap canister...the donor is in the back, ranger in the front, I'm thinking of staying with the ranger setup, Not worried about emissions here, so its low on the list. However, since the donor was already half apart when I got it, I had trouble tracing and locating the plug for it, still haven't traced it down yet. The entire engine bay harness (headlight harness) is removed with the exception of engine operating harness, which is atop the motor. The fuel lines on the V8 look a little short to reach the ranger fuel lines, however, I think I can move the ranger lines a little to make em reach...Not sure what I'm gonna do about the airbox/intake yet, I know I don't want a factory setup, will figure it out when I get to it...
I originally was planning to do this swap in a day's time, but when I realized just how much is different, decided to take it slow and do a complete breakdown and writeup to help others considering a swap for this year...
Any questions, comments, suggestions?? I will start a complete build thread After I am done with the install so everything is together and not spread out over 50 pages...
SVT
What I know...
SVT
