- Nov 13, 2018
- Canaan
- State - Country
- NH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Automatic
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
Let's talk like Ford guys because I assume we are.
No Ford ever had a "posi", positraction was a GM name for their limited slip. Ford's used Traction Lok differentials, or later limited slip, and some of them had optional Torsen differentials.
Unless you installed a DUI unit, no Ford had HEI. Duraspark, Thick Film, DIS, EDIS, Coil on plug were all used.
Toyota sells extended cab "trucks", Ford offers 2 and 4 door Supercabs.
The computer that runs the powertrain was called a processor back in the EEC I,II,III,IV days, then became a PCM when OBD II mandated common names for some components. It was never an ECM.
That round thing the tire is mounted on is a wheel, the rim is only part of the wheel.
I'll get off my soap box now.
