Thanks for the lead bobby! Very reasonable prices.be controls has the auto trans covered.
Yes, I'll give a run down later of the mods needed to get to this point. As I pointed out earlier (in a couple spots): 1) this equates to a 800hp duramax so think of that in terms of what needs to be modified to make this amount of power reliably 2) He has crossed the magic 200hp threshold (for a tdi) which means he had to go into the lower end to beef things up as well as improve the breathing of the head.what kind of coin to get to that?? anybody know for sure.??
Run down of mod list to get to this power level (hold onto your shorts
): from tdiclub build thread said:AHH with 11mm IP $750
PD Lift pump free
Rosten H-beam rods $600
ASZ 18.5:1 PD pistons $750
R520 nozzles set to 230/340 bar $500
Stage 2 Colt cam $400
Ported head $800
GTB2056VL on a ported 1.6 TD manifold with adapter plate $1300
2.5" exhaust, 2 resonators
SBC Stage 2 endurance clutch
Upgraded head bolts and main bolts $150
EVOMS FMIC
Custom boost piping
Custom intake.
4bar map $100
Yeah, that's over $5k in performance parts. Keep in mind that you can get there cheaper (buying used parts, looking for deals, etc). I'll be posting my details later on the prices for the injection pump, exhaust manifold, turbo, injector nozzles, etc when I get there. It is NOT going to be anywhere near that expensive....closer to $1500 and I'll be nearing 200whp.
