- Apr 14, 2020
- Colorado
- 2.5L
- Manual
- Total Lift
- Stock
- Tire Size
- Stock
The truck is a '98 XLT with the 2.5l 4cyl, manual. When driving (hot or cold, highway or in town, 25ft or 200 miles) the engine speed stays high, or goes higher, when depressing the clutch. It will stay there, no matter what, never come down, until the truck comes to a dead stop. I've coasted for miles this way, hoping it would drop down to idle like any normal vehicle would. Like so many others I have looked and searched high and low for this same problem, found many solutions, and no luck with my particular truck. I inspected everything, vacuum lines, electrical connectors, particularly the TPS connector, the entire intake manifold, and started testing and replacing likely culprits. The truck has almost zero issues now but for this problem.
So far I have replaced the VSS with three different units (all good working sensors), the IAC valve, the EGR valve, the DPFE, the purge valve, both O2 sensors, the MAF sensor, the TPS sensor just today, and a plethora of other parts in resolving other issues such as: vacuum lines, EGR pipe, timing belt, intake gaskets, head cover gasket, thermostat housing and sensors (rest assured the problem persisted before and after). I opt for Motorcraft when available. Some other facts, the throttle body has been cleaned (I've heard this is an issue, I have an older spare TB from a Maxda 2300 but unsure of its condition - although that truck ran) and the truck has a perfectly functioning Sportrac cluster as the original speedo had stopped working (stuck indicating 50mph until stopped, possibly related, no luck researching that issue until I replaced the entire cluster). I have no trouble codes, and I do own a OBD2 reader that can do some live data. The ABS light is always on, but will flash if I brake and change gears at the same time. The only thing I haven't tried is charging the A/C, although it blows cold I wonder if it could have an effect if pressure is low.
What a mess! At any rate the truck is great, but this stuck RPM issue has me going crazy. I'm going camping this weekend to get away from it, if anyone bites on this hook - I'm definitely curious what I am missing or ignoring. I'm open to any and all suggestions, even if I've done them before. Hope I catch lots of trout up there, maybe something here too!
