Fsmith
- May 19, 2025
- Spring Hill, Fla
- 3.0 V6
- Total Lift
- 5/4
- Tire Size
- 31
New member here. Having trouble with a trans swap and wiring and home some of you can help.
2002 Ranger Edge Tremor sthe automatic transmission to a 2003 5spd.
Used a 2003 manual ecu
2005 manual engine harness.
2002 original dash harness w/o clutch switch plug.
Having trouble programming the pats system, the ecu is being recognized, but keeps losing connection.
Not sure exactly which wires to tap into to add the clutch safety switch into the existing dash harness or if it’s even possible.
Does the engine harness even have the past wires in it or is it wired for the HEC and I’m screwed and have to get a new harness or even possibly another ecu from the 05 since the didn’t have the pats in 05?
