stock leafs???
TheRedRangerRidesAgain
Port Angeles, WA
the leafs in my ranger are SHOT. I called the local ford dealer and they told me that those leafs are obsolete, does anyone know where I can get a set of factory replacement leafs or maybe some kinda of performance ones, I don't have any lift and would like to keep it that way, its a '97 2WD reg cab short box, if that helps, thanks
Check your local wrecking yard. Should be about $50 a pair.
Check Summit. I know they have lift leafs, they may have stock as well. Prepare to pay though.
You should be able to find some sort of spring specialist around you. Look in the yellow pages. They can usually make custom leafs.
i just checked jcwhitley, it shows they have them for a 1997 ford ranger, one was $119.00, dont remember the other one. but you can check it out.
arent all rear leaves from any ranger pretty much interchangable?
