Was doing trans service and valve body gasket replacement on 4r44e (2000 2wd)
I sat down for a second after it was buttoned up and some fluid was going through the funnel and saw a piece of paper inside the filter box. The paper said to use the included bolt when putting on the filter. I did not do that.
So before I go putting more fluid into this thing, do I need to drop the pan and swap that bolt out? Or am I good with the original bolt on the new filter? It doesn’t look much different, just a smaller bolt head.
ugh - thanks in advance.
