GingerKing13
- Dec 2, 2016
- Defuniak Springs, Fl
- 1988 Super Cab
- 2.9 V6
- Total Lift
- 2 inches
- Tire Size
- 31x10.5xR15
1988 Super Cab FM146 BW1350 manual shift/manual hubs, Extreme vibrations when hubs are locked in 2WD and 4WD... It feels Fine when hubs are not locked in 2WD!
This started during a day of wheeling at the end of the day. Suddenly I had a very noticeable vibration from the t-case shifter and the gear shifter, enough that it shakes the truck... I have done under it and everything looks intact but there is some 'slop' or play on the T-case end of the front drive shaft. The fluid is fresh and full (changed about 8,000 miles ago). I have never replaced the U-joints and I have had the truck for 6 years. Could this just be a U-joint that's bound up?
Thanks for the help!
