- Jan 19, 2017
- Hogne Belgium
- 2.9 V6
- Automatic
Hi, I just replaced the O2 sensor, I have code 42 rich system, if I reverse the two sensor wires I have 41 lean system, any ideas?
In addition I have code 13 idle too high but I can't adjust it, I have a new IAC and when I put the old one back the idle is a little lower but still too high, I don't know if it's because of the IAC or the tps.
I also have the oil warning light that comes on at idle, it goes off if I give a little gas, the level is good; oil pump problem?
