SOLVED: 1988 2.9L 4x4 EXT cab | what fuel pump is the right one for my tank?
No, I don't have anything like that
Because the tank is longer than wider there should be 2 baffles inside, separating the tank into 3 parts, front, middle and rear
What you can do is tap on the bottom of the tank after it "runs dry"
Empty section should sound way different than a section with gas still in it
Should be able to put in a "coat hanger" type wire and feel the baffles
Check with local tool rental places or Auto parts stores to see if they rent "Bore scope" or endoscope cameras
If you have a plumber friend he will have one or know where to get one, lol
Have seen those now with USB C plugs for smartphones, not too expensive but never tried one of those myself
I dropped the tank this afternoon and am able to see inside of it. No baffles to see.... I have never replaced the tank since I've owned it, could it be a tank for a bronco 2? The hole for the sending unit is all the way in the back. I will attach a photo of it here. The pump seems to be at the bottom of the tank and the gauge says just under a 1/4 of a tank which fuel level seems to be true. I will pour the fuel out of it and measure when the weather passes. I am stumped.
Your tank is different because you have a extended cab. If you look at the pictures, the regular cab tank is slanted down in the front, the sending unit and pump has barely enough room to fit under the back of the cab. The frame kicks up when it gets to the bed. A extend cab truck is going to be worse, with the cab coming back so far, there is no room for the pump/sending unit. I never had a extended cab but did have a regular cab truck and put a new tank on it. So I am assuming your sending unit/pump is at the rear of the tank because it's a extended cab tank. Thus the different pickup/pump angle also.
There are no baffles in the tank, that is the reason for the fuel reservoir. The later tanks have no baffles, they have the sending unit/pump that has the plastic can around it to use as a baffle/reservoir.
Gotchya, the reservoir is mounted on the frame before the high pressure pump. There is no plastic can around the pump/sending unit.
SOLVED!
I replaced the "VENT VALVE" Dorman #: 911060 on the top of the tank and it fixed my issue! Pressure was not releasing from the tank once fuel level reached connection of the filler neck to the tank.
Ended up replacing the tank as well due to the crud that had built up from the rusting innards.
Thank you everyone for the input
