sluggish 289
The damper may be off as far as TDC but its not going to change with engine rpm. What kind of distributor do you have and does it have a vacuum advance.
From what I have been reading you want base timing around 8-10 degrees and total advance (all in) between 32 and 34 btdc thats a 24 degree curve or there abouts.
Set you base timing to 14 degrees as a test. Let us know what happens.
Pete
