Rampager
- Oct 6, 2010
So in the very near future I am buying new shocks for my 96 2wd B3000 and have almost decided on Skyjacker with a front 2 inch coil spring leveling kit as well. But looking into shock sizing has me confused now. The rear shocks I'm getting are the N8058 and are spec'ed for between 0" and 3.5" lift which is fine because if anything I might put a 2" block back there but for now is staying stock height. In the front I am going to get the Skyjacker 2 inch leveling kit which is simply longer coils. My stock front shocks are almost exactly 15' extended length and 5" stroke but the N8052 shocks Skyjacker recommends for up to 2" lift are only slightly larger in size.
• Collapsed Length (in.): 10.02
• Extended Length (in.): 15.69
• Shock Stroke (in.): 5.30
Could someone clarify how I will still manage to get a 2" lift when the recommended shock has an extended length of less than an inch more than stock? Wouldn't the shock top out and limit the change in ride height? Wouldn't I be better suited for the N8054 which seems to be sized better for a 2" lift above stock?
• Collapsed Length (in.): 11.52
• Extended Length (in.): 18.66
• Shock Stroke (in.): 7.14
Any help or advice would be greatly appreciated! Thanks in advance!
